Oil leak?
Old Nov 22, 2010 | 01:37 PM
The beast is reborn's Avatar
The beast is reborn
Default Oil leak?
I feel like a tool. Can stop oil filter from leaking. Any suggestions?
Old Nov 22, 2010 | 01:55 PM
Get a different filter. They probably gave you the wrong one.
Old Nov 22, 2010 | 02:42 PM
J415's Avatar
J415
+1 also make sure the rubber o-ring gasket didn't get stuck on the block causing it to not set well.
97r/tram's Avatar
97r/tram
The fram extra guard ones (silver ones) do this the easiest.
Old Nov 22, 2010 | 05:55 PM
Aubrey's Avatar
Aubrey
Have your girlfriend tighten it for you. LOL Just kidding.
Yeah, you either have the wrong one, cross threaded it, or some of the rubber seal from the last one is still on there.
Old Nov 22, 2010 | 06:04 PM
zman17's Avatar
zman17
Retired Moderator - RIP
How are you tightening it? Make sure both surfaces are clean, and wipe a small amount of oil on the gasket with your finger. Hand tight, then maybe 1/2 to 3/4 turn with the wrench after, and that's it.
Edit: And get a WIX filter. #51085
Old Nov 22, 2010 | 06:15 PM
The beast is reborn
Tried two new filters two different types, made sure old gasket was removed, cleaned mating surface, ensured gasket was wet with oil, and had my GF tighten as much as she could. Next step would be installing with filter wrench???? Anymore ideas?
Old Nov 22, 2010 | 06:19 PM
zman17's Avatar
zman17
You sure it not leaking from above? Like the Valve Cover.
Old Nov 22, 2010 | 06:30 PM
The beast is reborn
No it's coming from around the filter. I cleaned it up pretty good because I first suspected the rear main seal since the truck sat for awhile. But I will double check just to make sure.
Old Nov 22, 2010 | 09:02 PM
J415's Avatar
J415
Did you change your oil filter when it was cold outside? If you are, try to warm the O-ring so that it can fit a little bit snugger.
