Cab lights...
Old Nov 27, 2010 | 09:42 PM
tj941500's Avatar
tj941500
Originally Posted by Baddnet
I have 3rd gen after market LED Recons on my 2nd gen..But I installed them different them most ppl do.. most 3 center lights are closer and the outside 2 are farther.. I did mine almost even all the way across..
would you mind posting up a pic of your cab lights??,,,, im really curious on how it looks
Old Nov 28, 2010 | 12:59 AM
99dodge318's Avatar
99dodge318
all 2nd gen rams have the cab light layout all ready under/over the headliner. you just have to drill the holes in the spots marked out.
Old Nov 28, 2010 | 10:14 AM
tj941500's Avatar
tj941500
i understand that,,, my only problem is.. the 2nd gen cab lights bolt on the right and left,, the 3rd gen lights are bolted on the front and back,,,, ,,, what i could do is drill a hole in the center of the layout marks for the wiring and then pull the wire through and square the light than mark and drill the holes for that light..
