Cab lights...
Old Nov 22, 2010 | 01:37 PM
tj941500's Avatar
tj941500
Default Cab lights...
does anyone know if i will run into any problems putting 3rd gen cab lights on a 2nd gen??? I didn't buy the cab lights yet and my truck doesn't have cab lights on it now,, so i would have to drill the holes and what not,,, i just want to know if i will have a problem with the curve of the roof and having gaps between the lights and the cab,,,,,
Old Nov 22, 2010 | 04:31 PM
dakota_raven's Avatar
dakota_raven
Check this out! From 1994-2011!
http://www.gorecon.com/products.php?p_cat=29
Old Nov 23, 2010 | 09:34 AM
Andrew2500's Avatar
Andrew2500
The lights will work on a second gen because some of the later second gens actually have the new style of lights. However the mounting template will not match up on the roof. From what I've read, the best bet is to remove the headliner, find the five holes for the cab lights and use those as a guide on where to mount them.
Old Nov 23, 2010 | 11:31 AM
tj941500's Avatar
tj941500
Ok,, thank you so much for the info,,, i have to take the headliner down to get it redone anyway... thanks...
Old Nov 23, 2010 | 01:41 PM
EricCartman's Avatar
EricCartman
They are different styles of lights for the different years. It isn't like one light universally fits all years.
Old Nov 23, 2010 | 05:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I have a complete set (OEM) in damn near perfect condition, with factory harness, from my 98 if you are interested.
Old Nov 25, 2010 | 07:49 PM
tj941500's Avatar
tj941500
thank you but i was thinking about going with these,,, something a little different
http://cgi.ebay.com/ebaymotors/DODGE-RAM-LED-SMOKE-CAB-ROOF-LIGHTS-DUALLY-TRUCK-_W0QQcmdZViewItemQQhashZitem53e0ebe492QQitemZ36025 5841426QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
Old Nov 26, 2010 | 08:44 AM
dakota_raven
They got them for Ram 1500 and 2500 between 1994and 2011.
Old Nov 27, 2010 | 05:42 AM
Ryans_Dodger's Avatar
Ryans_Dodger
I would be interested in those cab lights and harness....
Old Nov 27, 2010 | 10:29 AM
Baddnet's Avatar
Baddnet
I have 3rd gen after market LED Recons on my 2nd gen..But I installed them different them most ppl do.. most 3 center lights are closer and the outside 2 are farther.. I did mine almost even all the way across..
