Front Coil Replacement
Old Nov 22, 2010 | 03:08 PM
oct6454's Avatar
oct6454
Default Front Coil Replacement
Hi, looking to get some stiffer coils for ym truck, its a 2001 1500. It has a 2.5in level in the front and 3in block on the rear. Right now i'm running some 33's and want a little more lift for my truck. That being said the first thing i want is some stiffer coils for the front, i dont like having to worry about bottoming out. I have thought about just adding 2500 coils to the front but would those work with my 2.5in level?
Also if i do decide to lift the truck a little whats the cheapest way to do that?
Old Nov 22, 2010 | 05:53 PM
Aubrey's Avatar
Aubrey
What kind of driving do you do where you're worried about bottoming out and with a 2.5 lift?
The diesel coils will gain you stiffness and more height. You should be able to use a set with your current lift and be fine. You may have to add an AAL in the rear to get it to sit level afterward though.
