Wiper fuse keeps blowing? HELP
Old Nov 23, 2010 | 01:15 AM
Camo Kid's Avatar
Camo Kid
Default Wiper fuse keeps blowing? HELP
OK yesterday afternoon my Wiper fuse blew? Hmmm I bought some fuses and replaced it and it seemed fine. This A.M. I am getting ready to leave and it's snowing so I turn on the wipers and it blows another fuse? Great!!! I pull back in the driveway change the fuse turn on the wipers and it blows another one!!! I jump on the net and google blown wiper fuses. Some people claimed that its probably a bad wiper motor? A friend stops by and I said I was going to go get a wiper motor. He runs me down to the parts store and on the way he says why don't you change the wiper relay first. OK so I purchase both the wiper relay and the motor. I get home and it's the wrong relay. I remove the existing one and go back and get the correct one. I changed the relay turn on the wipers and it doesn't blow a fuse. I call my buddie and thank him. This evening I leave to return the wiper motor and it's still snowing so I had the wipers on. I get a block from my house and the fuse blows!!! I go back home swap the wiper motor out that I thought I was just taking back? Turn on the wipers and POW it blows another fuse!!! I just got back from the parts store they had a wiper switch/turn signal arm but no intermittent wiper module. Anyone know what to check? Could it be the wiper switch/turn signal arm shorting out? Could it be the intermittent wiper module?
Old Nov 23, 2010 | 05:54 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Remove the covers off the steering column and check for broken or shorted wires.
Old Nov 23, 2010 | 04:48 PM
Camo Kid's Avatar
Camo Kid
I removed the electrical plug from the wiper motor than I changed the wiper switch/turn signal hi/low switch. I inserted a new fuse turned on the wipers and it didn't blow the fuse. I then reconnected the wiper motor and turned on the switch. It did not blow the fuse. I thought I had it repaired and put everything back together. I was turning the wiper switch on and off to align the wipers before I attached them and the wipers quit working. Now it blows the fuse again when you turn on the wipers?
Old Nov 23, 2010 | 04:50 PM
Unplug the wiper motor, replace the fuse, play with the switch. If the fuse does NOT blow, replace the wiper motor.
Old Dec 28, 2010 | 12:02 AM
Camo Kid's Avatar
Camo Kid
I had a short in the firewall. Thanx
