Slotted/drilled rotor, heavy duty???
Old Jun 9, 2005 | 02:58 PM
Silver_Dodge's Avatar
Silver_Dodge
Default Slotted/drilled rotor, heavy duty???
I am having some overheating on my front disk brakes. Result is that my rotor is glazing up. I need to get my rotors machined, then next week I am going to get a brake system flush. This should help some. Also will probably install some ceramic pads to replace the metallic pads I currently have. Ceramics don't generate as much heat.
My question is this: Has anyone found a slotted or drilled rotor that is heavy duty enough for towing and load applications. Most slotted/drilled rotors I know of are not as strong as a conventional rotor. They definetly help keep your brakes cooler, but what good is that if they crack on you when braking under a load.
Thanks.
Old Jun 9, 2005 | 03:40 PM
steve05ram360's Avatar
steve05ram360
Default RE: Slotted/drilled rotor, heavy duty???
On the M3... you tend to stay away from the cross drilled rotors for the cracking reasons... slotted should be fine
