5.2...odd smoking habit
Old Nov 28, 2010 | 08:32 PM
Dantra's Avatar
Dantra
Default 5.2...odd smoking habit
I have someone wanting to trade me a 97 1500 4x4 with a 5.2 for my Durango. It's pretty much an even up trade, both vehicles have issues. But I want a truck and he wants an SUV so...
Anyway, the truck starts up and has a little blue smoke that develops into ALOT of blue smoke and after a few minutes, clears to just a little smoke. My first thought was valve seals, nut thats usually right at start up. The heads have been redone in the past 6 mos and the truck has 130,000 miles.
Any common problems that come with these 5.2s that might cause such a problem? A little...then alot...then back to a little. Also sounds like maybe a slight miss at idle.
Old Nov 28, 2010 | 09:26 PM
Aftermarket PCV valve....... they suck. Literally. Pull oil right out of the valve covers. Pull the hose off the valve, see if there is oil in there. A drop or two is ok.. if it dribbles out... .there is one problem.
Also could be a badly blown plenum. Look down the throttle body, see what you see. If you see oil.... yep, its bad.
Old Nov 28, 2010 | 09:38 PM
Dantra's Avatar
Dantra
HeyYou....yea You! Thank You. I"m probably going to go for it, just crossing my fingers at this point.
Old Nov 28, 2010 | 10:41 PM
CPTAFW163's Avatar
CPTAFW163
sounds like a plenum or PCV to me. The only other culprit is bad valve seals, but that would only be at startup and for maybe a mile or two.
If it is bad valve seals, yo will need new heads, or bring them to a machine shop to redo your current heads. However, I would advise against milling/rebuilding stock heads. THey crack easy enough without being touched.
