how to remove fan clutch
Old Nov 28, 2010 | 10:09 PM
dipsherry's Avatar
dipsherry
Default how to remove fan clutch
i was going to put me e fans on today but i went to the auto parts store and rented a fan clutch removal tool... i couldnt even figure out how it was supposed to work...how do i keep my pully from turning also do i losen clockwise or counter clockwise
Old Nov 28, 2010 | 10:16 PM
Pacmanloads's Avatar
Pacmanloads
counter clockwise..... I used a piece of 3/4" flat bar and drilled 2 holes in it . Placed 2 bolts though the flat bar and through the holes in the pully in order to hold it in place . I then put a long pipe on it for leverage and a wrench on the nut and give it a really hard quick jolt....it actually came off fairly easy , but maybe i just got lucky . Good luck .
Old Nov 28, 2010 | 10:33 PM
dipsherry's Avatar
dipsherry
Talking
did u place bolt trough the pulley then another through the alternator bracket or what...cause that was my idea
Old Nov 28, 2010 | 10:45 PM
Pacmanloads
I'm sure you could make that work.....but from what i remember i used 2 hole in the pully itself . an it was actually a piece of angle Iron i had laying around....1/2" x 1/2" .
Old Nov 28, 2010 | 10:51 PM
Flue's Avatar
Flue
Rubber strap wrench on the pulley works pretty good, wedge against frame (I think) big crescent, breaker bar and she'll slip right off. No problems.
Old Nov 28, 2010 | 10:53 PM
Pacmanloads
you will get it !
Old Nov 28, 2010 | 10:56 PM
dipsherry's Avatar
dipsherry
this could b interesting lol i will try to get at it after work tomorrow...i guess i will take pics might succeed might fail who knows
Old Nov 28, 2010 | 10:57 PM
Pacmanloads
Never thought of the strap wrench. That would work too ... you'll be fine....you'll get it off .
Old Nov 28, 2010 | 11:03 PM
dipsherry's Avatar
dipsherry
what size is the bolt i am using a crescent wrench but she is kinda wollered out...i figure i will buy a wrench that will fit so i dont strip it and ruin my chances
Old Nov 29, 2010 | 01:10 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
An air hammer with a chisel or pointed tip works best. Barring that, a piece of metal stock sharpened to a chisel tip or point that is long enough to contact the nut and hit the top with a hammer. Much faster, mush less likely to result in skinned knuckles. For reinstalling, just thread it on about 2 turns and start the engine. It'll self-tighten.
