4x4 shifter problem
Old Nov 29, 2010 | 09:43 AM
The beast is reborn's Avatar
The beast is reborn
Default 4x4 shifter problem
95 1500 auto was having trouble shifting into in 4H, keeps popping out. Tried to adjust linkage but the rod from the TC to the bottom of the shifter assembly was servere damaged. Where can I get a new one of these? Should I be looking at the junkyard.
Old Nov 29, 2010 | 10:40 AM
KY BIGRAM's Avatar
KY BIGRAM
What do you mean by "severe damage"?If it's still hooked up it is not too severe. If it is bent then take it off, straighten it and put it back in place to see if this will correct your issue. If it does then replace it or have someone with a welder reinforce it with another small plate or something. I have one that has been bent and it does not line up the gears correctly.
Old Nov 29, 2010 | 10:34 PM
The beast is reborn
Thanks I will give it a try
