High Voltage
Old Nov 30, 2010 | 12:33 PM
yzinger's Avatar
yzinger
Default High Voltage
Hey guys, hows it going.
Since i replaced the coil in my truck (95 ram, 4x4, 318 auto) it seems the voltage gauge reads high. Maybe 15/16 volts. Last night i found out one of my plug wires (the coil one i believe) was arcing. Is this the issue of the high voltage?
Thanks.
B
Old Nov 30, 2010 | 12:43 PM
Nope, quite unrelated. If you had a plug wire arcing to the rest of the electrical system, you would see many more problems than just the volt gauge reading a bit high.
Check voltage at idle, at the battery, the stock gauges are not exactly known for their precision....
