Evap? Is there a problem?
Old Nov 30, 2010 | 07:57 PM
01Rammer's Avatar
01Rammer
Default Evap? Is there a problem?
I am throwing evaporative emissions code(both of them) i was just wondering could this cause any problems? I have not really paid any attention to it. But in another post a guy said he was getting horrible gas mileage from it and what not. What does this code involve? Evap canister, lines, hoses, fuel tank, etc.
Old Nov 30, 2010 | 08:20 PM
Ralpho's Avatar
Ralpho
I just bought a 2000 1500 and am getting P1495 what code does yours say. I just got a scanner and can look up the code. If that helps
Old Nov 30, 2010 | 08:26 PM
SawFan862's Avatar
SawFan862
I have the same issue, in my case though I know the issue, my evaprotive canisters are broken in multiple places. I would check all the hoses, starting from the engine bay, working to the evap canister(s), and to the fuel tank. On a single cab, and quad cab, the canisters are different (who knows why!). But this does kill Mpg, i was getting 13, but now i get more like 11-9mpg.
Old Nov 30, 2010 | 08:31 PM
Ralpho's Avatar
Ralpho
Where is the canister
Old Nov 30, 2010 | 09:34 PM
dhvaughan's Avatar
dhvaughan
canister on my 01 is under passenger side cabin.
the small leak, large leak p0455, etc doesn't usually cause a problem with how it runs. it does indicate that your leaking gas fumes, so you wouldn't want to park the truck inside the basement or in a garage with a pilot light. something bad could happen.
if the leak is in the canister side, the engine usually runs ok. if the leak was in the throttle body side, it might have a full time vac leak and throw a lean condition code.
the only other thing bad is that when an evap purge cycle occurs, it might open up a vac leak. this might cause some intermittent problems and might or might not throw a lean code.
i've had a p0455 code for a long time i haven't been able to solve. the truck still runs fine and gets good mpg.
Old Dec 1, 2010 | 07:14 PM
01Rammer's Avatar
01Rammer
Yeah im throwing the large and small leak. I have single cab. Its also idling rough on cold startup, random misfire. My mpg sucks. Could evap be related to any of the conditions i said?
Old Dec 1, 2010 | 09:47 PM
dhvaughan's Avatar
dhvaughan
i don't think so.
running wise - the worst thing that an evap leak could do is cause a vac leak and a lean condition.
you could prove that it is or isn't by locating the vac line from the purge solenoid to the manifold/throttle body, and disconnecting it at the manifold and plugging the port.
for rough idle and mpg, look at the basics - plugs, cap, rotor, wires, front 02 sensor, etc. if idle speed isn't acting right, replace iac and/or tps. depending on a lot of things, the very best mpg you could hope for will be around 15-16-17 mpg. i get about 13-14 city and 15-16 highway with gentle driving.
for your evap leaks, check the ends of all the vac hoses in the evap system. cut off a couple inches as needed to eliminate splits. replace gas cap. here's a pic of my canister with split hoses.
https://dodgeforum.com/forum/2nd-gen...-leak-fix.html
