oil pan gasket
Old Dec 6, 2010 | 01:17 AM
  #21
pduffey8709's Avatar
pduffey8709
Ooops. You may get to dive in there again then. I would first make sure that the oil isn't simply running down from higher up, and then dripping off from the lowest point....
yep maybe its the valve covers cuz theres quite a bit of of oil up top i also pressure washed the entire underneith today so i should be able to locate the leak more easily and about to replace the pcv valve. ill keep yall posted.
