Symptoms of failing rear diff?
Old Dec 4, 2010 | 10:21 AM
charlie1935's Avatar
charlie1935
Last year I thought I had a helluva problem. Noise all the time, accelerating, decelerating and at a steady speed. Nothing changed the tone but the speed. New tires fixed it
Old Dec 4, 2010 | 10:36 AM
CSXfan's Avatar
CSXfan
Thanks guys. I forgot to mention that its an open diff. So the easiest way to check a driveshaft u-joint is to get the rear wheels off the ground and see what moves around? Sounds easy enough.
And just in case it is a pinion bearing, the whole diff would need to be rebuilt correct?
Old Dec 4, 2010 | 10:38 AM
95RAM360's Avatar
95RAM360
yes, but IMO, you could get a whole rear axle assembly that has the same gears, and just swap it out....ive done it on the ground with no power tools, by myself in about 5-6 hours.....
Old Dec 4, 2010 | 11:14 AM
zman17's Avatar
zman17
Retired Moderator - RIP
If it is the pinion bearing, the seal would most likely be shot also, and grease would be getting flung all around too.
edit, providing it's not real low or empty.
Old Dec 4, 2010 | 12:18 PM
Sheriff420's Avatar
Sheriff420
That's my sisters truck in the video. The pinion bearings had a little chunk missing from a roller or two in them and that was causing the noise but the only symptom was the noise because they hadn't exploded yet. The seal wasn't leaking either. So the seal leaking will depend on how bad they're damaged if that is even the problem. Let chipped bearings go too long and they'll eventually blow up on you and could damage the axle housing and gears then it will cost a lot more to fix.
Old Dec 4, 2010 | 12:48 PM
zman17's Avatar
zman17
I agree 100 percent, but lets fix what we know is wrong first.
Old Dec 4, 2010 | 01:06 PM
HammerZ71's Avatar
HammerZ71
Fix the U-Joint, I agree if you KNOW it's bad, fix it first. Rare to see a bad pinion that didn't have the seal go first, so looking for leaking fluid around the seal would be an easy thing to check for.
Old Feb 22, 2011 | 05:58 PM
Tubthumper's Avatar
Tubthumper
Default 2002 durango rear end cladder
I've been having a problem lately with the rear end in my Durango, when i let off the gas there is a cladder sound like a roller coaster going up the hill. I had the pinion bears replaced and it still makes the noise, the guy at the garage is not sure of the problem. Anyone have a suggestion as to what the problem might be?
