Whats the right way to correct this bumper gap?
Yep agreed , in order to get the bumper where it should be you will need the relocation brackets. More than likely it is a homemade body lift. Not sure if you can buy those brackets separately or not . I would examine the lift and make sure it's safe , if not replace it with a proper lift that will include the brackets....Or you could just build a custom bumper to fill in the gap ! Hope you can fix the gayness .
on
I'd give Performance Accessories a call, they include front bumper relocation brackets with their kits. They may very well sell you a set for the front of your truck.
I agree, that looks terrible.
A good buddy of mine had his Cheby Z71 lifted with a combination 3" suspension lift and 2" body lift by a local shop. Because he has a grill guard and winch (same as mine, actually) the shop had to make brackets for the bumper and grill guard/winch mount out of heavy steel so he could still use the winch. Not a hard fabrication by a decent shop.
They didn't do anything for the rear bumper though, so I cut him a "filler piece" out of a sheet of diamond plate. It matches his tool box and diamond plate rail/taigate guards perfectly and was a relatively inexpensive fix...
