Still No speedo...getting very angry....
Old Dec 5, 2010 | 12:04 PM
With the engine running, there should be 5 volts on one of the wires for the speed sensor.
Old Dec 5, 2010 | 12:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Isn't there like a gear or something for the speedo on a 95 also. What year did the new TC come from?
Old Dec 5, 2010 | 12:32 PM
95RAM360's Avatar
95RAM360
i thought it was 98, but when i went back to my old boss who sold it to me, he said it was 95.....has all the same part numbers on everyting, i matched it to my t-case
Old Dec 5, 2010 | 01:21 PM
Aubrey's Avatar
Aubrey
During all of this did you pull the speedo housing off of the t-case or just the electrical connections?
Also, have you checked to make sure you don't have any bent pins in that connector or maybe some loose wires in it?
Old Dec 5, 2010 | 01:51 PM
95RAM360's Avatar
95RAM360
i took the whole piece out, and tried both on new t-case......with my new sensor it came with a new electrical connector i had to splice in, so it would fit new sensor, so i know its not from the hook up....
Old Dec 5, 2010 | 02:39 PM
95RAM360's Avatar
95RAM360
ok now i looked into the haynes, and you are right Zman.....theres a red and white wire that goes to transmission relay, and fuel pump relay.....and when i spliced the new connector on last night there was a red and white wire i had to splice.
but i also see another section of a transmission relay that has a light green and black wire....havent seen this one, could this be the one in the diff?
Old Dec 5, 2010 | 02:47 PM
zman17's Avatar
zman17
I don't know man, you are just going to have to trace the wires and look at the wiring diagrams..
Old Dec 5, 2010 | 03:08 PM
95RAM360's Avatar
95RAM360
i also read this;
Quote from Haynes
"Turn the VSS assembly until the correct index numbers on the speedometer adaptor are positioned at 6 O'clock. For Example: if the speedometer pinion has 35 teeth, position the 32-38 index number straight down (6 O'clock)."
I never did this, i just wiggled it in until it was all the way in and twisted it so the clamp would line up.
Old Dec 5, 2010 | 04:00 PM
95RAM360's Avatar
95RAM360
WOW...i feel like an idiot....
took out the whole speedo adaptor, and looked on the splines on the gear....there was 30, so i put the 26-31 punchmark at 6 o'clock. and boom i have my speedo again.
Took her on the highway felt the TCC lockup, and then it shifted smoothly into overdrive...
FINALLY my truck is back in order. didnt know something that small could make such a difference....should have read the haynes before i just changed out sensors....could have saved $32 on a sensor.......but what the hell, its new so i dont have to worry about it.
Old Dec 5, 2010 | 04:13 PM
zman17's Avatar
zman17
Glad you got it working, I thought there was some sort of gear thing with a 94/ 95.
