Check engine light flashing
Old Dec 6, 2010 | 04:12 PM
BlueBeast2's Avatar
BlueBeast2
Originally Posted by fascistfaction
See if your oil is 'milky' similiar to coffee with creamer. If it is black then the head is fine,
FF
That's actually not true. I believe mine was cracked and the oil was fine. I believe others that had cracked heads didn't have any oil problems either
Old Dec 6, 2010 | 05:43 PM
dodgeman52's Avatar
dodgeman52
i have autolites 3923s
Old Dec 6, 2010 | 07:13 PM
97ramnj's Avatar
97ramnj
my cel used to flash, it was a misfire code
Old Dec 7, 2010 | 07:24 AM
9eightram's Avatar
9eightram
Default CEL Flashing
Well a new update. The Check engine light stopped flashing, now it stays on. I gotta get it to the garage to see whats goin on with it. At this point I hope it is the plenum gasket. Plan on changing the plugs as well. I'll keep you all posted if I find anything abnormal.
Old Dec 7, 2010 | 07:32 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You can try this to read the codes , but most people have no luck with a 98. https://dodgeforum.com/forum/2nd-gen...code-list.html
