Rear Brake Drums - Can't get them off.
Old Jun 11, 2005 | 12:39 PM
Two60s98's Avatar
Two60s98
Default Rear Brake Drums - Can't get them off.
Damn Illinois rust! (Previous owner)
Can't get the rear drums to come off. I've sprayed them with penetrating fluid overnight, and beat them carefully with a dead-blow rubber mallet. Still holding strong. Anyone else have this trouble and have a suggestion?
Old Jun 11, 2005 | 01:41 PM
Two60s98's Avatar
Two60s98
Default RE: Rear Brake Drums - Can't get them off.
Update:
The right rear is now off. Ended up using a block of wood on the back edges near the backing plate and hitting the drum outward. The left side is still being a Beeaaatch!
Old Jun 11, 2005 | 02:41 PM
Redneck2345's Avatar
Redneck2345
My old chevy had this problem constantly, I had to heat the center of the drum with a torch, where the hub sticks through, and than pound on it with a hammer
Heat is your friend!!!
Old Jun 11, 2005 | 02:47 PM
garpoonga's Avatar
garpoonga
When you put it back together give it a generous coat of never seize. I inspect my brakes twice a year and since I started using the never seize I haven't had a problem.
Old Jun 12, 2005 | 06:30 PM
zeekxxx's Avatar
zeekxxx
I used a 5 pound sledge hammer.
Careful not to warp it
Old Jun 12, 2005 | 10:33 PM
Two60s98's Avatar
Two60s98
I'm up to my 4lb. one, and still won't budge the left one. I'll keep at it. No heat source in my garage.
Old Jun 13, 2005 | 11:13 AM
Two60s98's Avatar
Two60s98
Update to the Update:
Well, after turning on some Pantera, and getting midevil on it, the left drum finally let loose it's hold on the hub. At the end I was swinging the 'ol 4lb like I wanted to split it in half. It was either gonna come off intact, or in pieces. Luckily it's still in one pieceI will definately be applying some anti-seize when it goes back together.
Old Jun 14, 2005 | 01:22 AM
2kramquad's Avatar
2kramquad
Go to Autozone and borrow a drum puller.
