hop hop hop
Old Dec 15, 2010 | 03:22 AM
offroadjosh's Avatar
offroadjosh
Default hop hop hop
When in 4wd and spinning i tend to hop pretty bad regardless of traction(solid ice with water on it or snow...etc) i also notice my drive side front tire(prolly passenger too) flops around like im sawing the steering wheel.. but im not. Any reasons? Its almost exactly like death wobble but just when spinning the tires... Never while driving. I also keep getting a weird wine noise when throttling on it hard(driving or spinning) and seems to becoming from the wheel bearing area... So anyone know? Hope that makes sense...
Old Dec 15, 2010 | 08:03 AM
DukesOfHazzard's Avatar
DukesOfHazzard
http://www.youtube.com/watch?v=QSGJRcrUkwo Found this video
Old Dec 15, 2010 | 12:05 PM
offroadjosh
..Guess I will be checking that once i feel better(still sick as hell...)
Old Dec 15, 2010 | 02:54 PM
99dodge318's Avatar
99dodge318
yeah im not sure but, i think you have to replace the whole unit bearing on these trucks
Old Dec 15, 2010 | 03:51 PM
rideordie's Avatar
rideordie
Yeah, ours is the bearing/hub assembly.
That is the worst wheel bearing I've ever seen ^^..And I thought mine was bad.. Well..Mine was pretty bad, but not that bad.
Old Dec 15, 2010 | 04:46 PM
offroadjosh
Got out of bed to check the wheelbearings today.. Both check out fine along with both ujoints and the entire front end(couldnt find anything) Both drive shafts are good too.. Any ideas?
Old Dec 15, 2010 | 04:53 PM
Jack up the front, put it in four wheel drive, (make sure the cad engages) spin a front tire. Feel anything unusual? Hear anything you don't think you should? (you can shut off the engine...... cad should stay locked.) Gotta have both front tires up off the ground though.
Old Dec 15, 2010 | 10:09 PM
offroadjosh
did that and nothing seems wrong.. Dont get it.. Major death wobble only when spinning in 4wd... and weird clank noise lol
Old Dec 15, 2010 | 10:17 PM
How about the control arm bushings? They may be 'enough' under normal circumstances, but, start putting power to the front wheels..... and maybe they are not?
