'94 Ram 5.2 Not Starting
Old Dec 15, 2010 | 12:17 PM
mjonesjr's Avatar
mjonesjr
Default '94 Ram 5.2 Not Starting
I have a '94 Ram 5.2 that will not start. When turning the key to the start position, it clicks but does not start. I have put a new starter, battery, and starter relay on the truck.
Anyone else have any ideas on what to check/replace?
Old Dec 15, 2010 | 12:27 PM
crazzywolfie's Avatar
crazzywolfie
you mean it won't even turn over? have you tried removing all the spark plugs at once and seeing if it would turn over?
Old Dec 15, 2010 | 02:19 PM
mjonesjr's Avatar
mjonesjr
It clicks like it is a bad starter, thus why I replaced the starter.
Old Dec 15, 2010 | 02:33 PM
crazzywolfie
have you checked the voltage at the the starter?
Old Dec 15, 2010 | 03:58 PM
Check the positive battery cable all the way from the battery, to the PDC, and then to the starter. There is a fat fuse/fusible link in the PDC.
Another member had this problem did some of the same things, and it turned out to be a corroded connection on the cable to the starter motor......
