'98 Ram wont idle
Old Dec 15, 2010 | 11:48 PM
Lone136's Avatar
Lone136
My wife has a 98 Durango and it was doing the same thing you are talking about. It would start and run as long as you gave it gas, but let the gas offf it would die. As it turned out to be the Throttle Position Sensor. I took it out and cleaned it and it ran fine, but I did go buy a new and installed it. It's on the back side of the TBI. Mine was heald on by two snall bolds.
Old Dec 15, 2010 | 11:52 PM
83 octane???? Where are you?
A bit of moisture out the tailpipe is normal. That's your catalytic converter at work for you.
Well, keep driving it, and see what happens........ Still, it really wouldn't hurt to pick up a throttle body gasket, (couple bucks) yank the TB, and clean everything really well.
Old Dec 16, 2010 | 06:06 AM
zman17's Avatar
zman17
Retired Moderator - RIP
That would be the IAC= Idle air control valve. Not TPS.
Old Dec 16, 2010 | 04:50 PM
Oakley Guy's Avatar
Oakley Guy
Im in idaho
Old Dec 31, 2010 | 02:48 PM
bonesbmx's Avatar
bonesbmx
well i found my problem it was the tps 15 min swap out and its been perfect ever since. i no this isnt my thread but wanted to say thanks. hope you figure it out.
