47rh trans problem
Old Dec 16, 2010 | 08:39 PM
6536jim's Avatar
6536jim
Default 47rh trans problem
Hi Guys,
I have a 95 ram 2500 diesel 4x2, I am having a problem
with 2nd gear in the transmission. It feels like it's slipping going
up hills but seems to be okay on flat roads. All other gears are
fine no slipping or other issues. Could I have a valve body issue?
Any specific info would be a great help. Thanks
Old Dec 17, 2010 | 12:08 AM
lukeca's Avatar
lukeca
I have a 95 ram 2500 with the v10, so I also have the 47rh. I am having the exact same issue as you. This is what Heyyou said:
Do a fluid and filter change, and a band adjustment. If that doesn't improve its attitude, milk it as long as you can before the inevitable rebuild.
