Ok need help lol brake lights
Old Dec 17, 2010 | 12:32 PM
Baddnet's Avatar
Baddnet
Default Ok need help lol brake lights
Hey guys..I need some help.. I lost all brake lights.. including 3rd light.. I have haz..turn..and parking.. but no brakes lights.. fuse is good..has power on one side of fuse..and power on both sides with fuse in.. which wire on the peddle switch should have power? with switch on the off position? Both wires should have power with the switch in the on position.. I dont seem to have power on either.. heading to get test light..
Old Dec 17, 2010 | 01:45 PM
Grab the Factory service manual from the faq section here. Has wiring diagrams I think you are going to need.
Old Dec 17, 2010 | 05:05 PM
Baddnet's Avatar
Baddnet
All fixed.. I pulled the brake light switch.." I know it says do not reuse " any way.. took it apart.. and found it was just plumb wore out.. 15 buck later..and have lights again.. Oh and the pink with blue is the hot wire.. the white with black ..goes to the lights
