Possible Air In the Steering gear lines
Old Dec 20, 2010 | 12:51 PM
mcss8541's Avatar
mcss8541
What is variable assist
Old Dec 20, 2010 | 12:56 PM
The amount of 'additional assist' contributed by the power steering pump when turning. Supposedly, at lower RPM, (which would be interpreted as Low road speed) more assist is provided, so turning is easier. At higher engine speeds (higher road speed) less assist is given, as at speed, you are not turning the steering nearly so sharp, or as often, and it is easier to steer when moving in any event......
Old Dec 20, 2010 | 01:16 PM
joshsbetterhalf's Avatar
joshsbetterhalf
I don't remember what it was that I broke. But I think it was the shaft coming out of or going to my pump.
Old Dec 20, 2010 | 01:21 PM
mcss8541's Avatar
mcss8541
Gotcha Thanks! One more question. My friend asked if my power steering pump is good and I told him as far as I know it should be, there's no whinning or humming. He said that it was possible that the pump is bad. I've driven on this new gear box now for 4 days and over 300 miles and still it's stiff. Not as but still stiffer than normal.
Old Dec 20, 2010 | 01:22 PM
joshsbetterhalf
Originally Posted by mcss8541
That was what I broke
That was, I was told, due to my steering gear box being seized up. Changed the gear box, changed the pump (x3 times total) and truck is fine. Steering is off by about 30* but, not the end of the world.
mcss8541's Avatar
mcss8541
Old Dec 20, 2010 | 01:24 PM
joshsbetterhalf
My steering stayed stiff, even after replacing the gear box, until AFTER we successfully changed the power steering pump.
Old Dec 20, 2010 | 01:26 PM
mcss8541's Avatar
mcss8541
Yeah I noticed that even though I but everything straight when I get up to highway speeds my steering wheel is turned slightly right in order to keep it straight I guess that's normal.
Old Dec 20, 2010 | 01:27 PM
mcss8541's Avatar
mcss8541
How did you know to change your power steering pump, was it humming or whinning?
Old Dec 21, 2010 | 01:12 AM
joshsbetterhalf
humming or whining would mean you have a high pressure leak according to my fiance.
What we heard which was the tell tale sound was a very quiet tick when the shaft snapped.
