Grinding noise?
Old Dec 20, 2010 | 03:39 PM
bobracing32's Avatar
bobracing32
Default Grinding noise?
959595 dodge 318 four wheel drive. Grinding noise from the rear axle I believe. But it only happens in two wheel. When in four wheel it only grinds once in a while. I believe its rear axle. Any ideas
Old Dec 20, 2010 | 03:50 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
pull your drums off and inspect.....
Old Dec 20, 2010 | 03:51 PM
put it up on four jackstands, and run it. Isolate where the noise is coming from. (BE EXTREMELY CAREFUL, rotating parts will grab ahold, and are NOT very forgiving. DO NOT DO THIS BY YOURSELF.)
Old Dec 20, 2010 | 03:54 PM
95RAM360's Avatar
95RAM360
you're t-case let go.....mine was doing the same thing.....replaced t-case and problem solved
Old Dec 20, 2010 | 03:59 PM
That's what I was thinkin' too. Just want to be sure before he spends money.
Old Dec 20, 2010 | 04:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
May be too late, but, can you say Transfer Case Saver?
Old Dec 20, 2010 | 05:15 PM
95RAM360's Avatar
95RAM360
dont worry ill be headin to your neck of the woods soon Zman to grab that one off you
