Old Aug 6, 2015, 01:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
super dim headlights
Old Dec 22, 2010 | 03:27 PM
dipsherry's Avatar
dipsherry
Default super dim headlights
what should i look for both my headlights work just really dim my driverside houseing isnt as dirty as passenger but passenger side is brighter what should i check
Old Dec 22, 2010 | 03:37 PM
J415's Avatar
J415
First and foremost, clean the lens if it's yellowed. Wet sanding worked for me. Then take it from there.
Old Dec 22, 2010 | 04:02 PM
merc225hp's Avatar
merc225hp
How old are the bulbs? get two new ones that match, check all the grounds and clean them, what is your alt gauge saying when the truck is running?
Old Dec 22, 2010 | 06:42 PM
lastrights's Avatar
lastrights
i had a blown fuse for the longest time and didnt know it till i did my halos.
Old Dec 22, 2010 | 07:41 PM
grox's Avatar
grox
Were the still lights on with a blown fuse?
Old Dec 22, 2010 | 07:43 PM
dipsherry's Avatar
dipsherry
alt gauge stays at least 14... the bulbs i guess will be a easy change the lens is not terrible but i will try it and see what i get
Old Dec 22, 2010 | 08:50 PM
dhvaughan's Avatar
dhvaughan
i cleaned my lenses with a dremel tool, buffer pad, and rubbing compound. it removed the yellow and made them more clear. i also replaced the bulbs with the super expensive silverstar ultra's.
they're better than they were, but they still suck.
my next move was to install a brite-box. this will draw criticism... when i switch on the brights, it illuminates both the dim and the bright filament. like when you hold the dimmer stick back. they create some LIGHT. i've seen plans to make your own, but i just bought one.
http://www.genosgarage.com/prodinfo.asp?number=BB-M4B
so what does it take to get lights ?
Old Dec 23, 2010 | 12:54 AM
lvolson's Avatar
lvolson
I'm voting for a bad ground.
It's amazing what a bad ground will do! Problem is, if it's not in an obvious place, they can be a %$#@ to hunt down.
Old Dec 23, 2010 | 01:07 AM
crazzywolfie's Avatar
crazzywolfie
that sounds like a good idea. having your high and low beam lights on at the same time. i might have to try it sometime. i had thought about trying some after market lights on my truck but i might not have to if that works.
Old Dec 23, 2010 | 12:54 PM
OZMarshy's Avatar
OZMarshy
Have a go at checking the voltage at the bulb. If it's not near 12 volts then check you earth. If your earths are fine put in relays so that you have high power from your batteries straight into the bulb.
If your not comfortable with checking out electrics I'm sure you'll have a friend who can help in that department
