motor blew up in my dads truck
Old Dec 28, 2010 | 04:40 PM
dodgeman52's Avatar
dodgeman52
okay well i have another question my dad found a 96 360 with on 60k on it and got it for a good deal and my question is can we can the intake and fuel injectors off the 318 and put it on the 360?will they flow enuff fuel?
Old Dec 28, 2010 | 08:16 PM
dodgeman52's Avatar
dodgeman52
anyone?
Old Dec 28, 2010 | 08:19 PM
John D in CT's Avatar
John D in CT
I couldn't swear to it, but I'd bet that the intake manifolds are the same. There's a better chance that the injectors are different, although the 360 PCM might just give the same injectors a bigger/longer squirt. Speaking of that, the 360 might not run so great with a 318 PCM. You might have a little more homework to do - and maybe try to get the PCM from the donor truck.
Why don't you want to use the manifold and injectors from the 360 - or are they missing?
Old Dec 28, 2010 | 08:26 PM
dodgeman52's Avatar
dodgeman52
well there from a 96 and the injectors have a different plugin compared to the 2001. were gettin hemifever to tune it but we are not sure about the injector thing
Old Dec 28, 2010 | 09:31 PM
Gerehead8's Avatar
Gerehead8
The 318 intake and injectors will swap on to the 360. The injectors are the same.
The FAQ's state that the 95 and prior 318's and 360's have different injectors but my 318 and 360 were both from 94's and the injectors were identical down to the part number.
Old Dec 28, 2010 | 09:36 PM
dodgeman52's Avatar
dodgeman52
okay thanks but will the 318 injectors work on the 360??? the truck is a 2001 and the motor is a 96. any help is greatly appreatied
drewactual's Avatar
drewactual
there is a difference in injectors wiring connectors.. I'm not sure where the cutoff was, but I think it was '98.. EV1 and EV6.. I have 'on body' adapters if you need some that make EV1 connectors match up with EV6.. I have eight, and will sell them all for $50 if you need them..
take a look at your harness though.. you may not need them- you may be okay with what you already have.
Old Dec 28, 2010 | 09:40 PM
matty675's Avatar
matty675
same injector flow and intake. but to put 2000 injectors on a '96 you'll need these
Old Dec 28, 2010 | 09:54 PM
dodgeman52's Avatar
dodgeman52
well can we just use the intake and injecters off the 318 so we aint got to buy those adaptors????
Old Dec 28, 2010 | 09:56 PM
drewactual's Avatar
drewactual
DOH!!!!
yup...
that's what I have...
and, apparently, I just put them on sale for $20.. I was thinking I paid more for them..
