Strange Electrical Problems
Old Dec 29, 2010 | 09:23 AM
a-master's Avatar
a-master
Default Strange Electrical Problems
So one evening I went out to drive somewhere and I flip the headlights on, but nothing happens. I pull the switch for fog lamps and nothing. I get out to inspect and notice that my tail lights are on like normal... so i get back in the truck because its cold as hell here and test the high beams, which magically work. I briefly consider driving with high beams, but then say screw it and cut them off. When I cut them off, back to normal mode, my regular lamps kick on like nothing happended. Its been fine for a week but the fog lamps still don't come on... ideas?
Old Dec 29, 2010 | 10:38 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Head light switch or multifunction switch come to mind...
Old Dec 29, 2010 | 10:45 AM
Or a relay that doesn't like the cold.......
Old Dec 29, 2010 | 11:11 AM
ramit99's Avatar
ramit99
Check the wiring in the steering column. If it has tilt the wires wear and break. Had major problems with mine. Lights stopped working and eventually it would shut the truck off when you put the steering wheel down. Had to splice and solder the whole harness. Been fine since then.
Old Jan 2, 2011 | 01:14 AM
a-master's Avatar
a-master
Hoping this is whats up, will replace soon...
Oh please don't be whats wrong lol
Old Jan 2, 2011 | 01:32 AM
jasonw's Avatar
jasonw
Site Moderator
The headlamp switch and/or multifunction switch are easy to replace. Only special thing required is a special tamper-proof or "secure" torx bit to get the steering column apart. Take at most a couple hours, and thats just for the most inexperienced mechanic at night with a flashlight (me when I first started doing my own repairs). Even less for the headlamp switch.
