Cranks and Cranks no Start
Old Jun 21, 2011 | 11:09 AM
  #31
klings designs's Avatar
klings designs
I will get on that then. I know i had a few different problems. One was the regulator on my pump so i changed out the pump.
Old Jun 23, 2011 | 05:41 PM
  #32
klings designs
Replaced plugs and coolant temp sensor. Still runs like garbage. I have noticed when warm if I keep tapping the gas it just feels like it misses. If this helps anyone.
Old Jun 23, 2011 | 05:42 PM
  #33
klings designs
Tapping it when it is ideling
Old Jun 23, 2011 | 05:45 PM
  #34
You have already replaced the cap and rotor haven't you? Wires? Have you ohmed out your injectors?
Old Jun 23, 2011 | 11:06 PM
  #35
kikidbird's Avatar
kikidbird
I had a problem with no spark on my truck after doing an engine OH. It ran fine before but then no spark. I replaced the Crank sensor and now I have spark.
Old Jun 24, 2011 | 06:46 AM
  #36
neilsrpcustoms's Avatar
neilsrpcustoms
Try unplugging the map sensor and starting it up, if it idles smooth,there's your culprit.
Old Jun 27, 2011 | 01:12 PM
  #37
klings designs
I replaced cap rotor and wires.
How do you ohm out your injectors
Old Jun 27, 2011 | 01:28 PM
  #38
aim4squirrels's Avatar
aim4squirrels
Check resistance by ohm meter on each prong of the injector. Should read 12 ohms +/- 1.2 ohms (10% discrepancy).
