driver window issue
Old Dec 30, 2010 | 08:20 PM
inkuyo's Avatar
inkuyo
Default driver window issue
Ok so we had some cold weather. 3" of WET snow followed by some sub freezing temps (25 low, 31 high). I do park my truck under a metal carport. I went about my business and had to open my driver's window, but it did not budge. So I made sure it was all up. Then later I tried again and it sort of 'fell' a couple inches and just did not look like it tracked correctly. So I push on it and made sure when I moved it up and down it tracked ok. I did not make it go all the way down, cuz I certianly did not want it stuck there. I closed the window and opened it a few times and it seems like it is back to normal.
Did it kick out of a slot holding it in place on the bottom? Should I open up the door panel and put some silicone in the track (I am assuming there is a track of some sort).
any ideas?
Old Dec 30, 2010 | 08:43 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
the clips at the bottom of the track are prob broke, pull the door panel off and do some investigating, look for anythign that doesnt look right, try working the window while the panel is off so you can see exactly what might be going wrong and go from there
