THROTTLE CABLE MOD or REPAIR W/E
Old Dec 31, 2010 | 01:33 AM
Nando Vazquez's Avatar
Nando Vazquez
Default THROTTLE CABLE MOD or REPAIR W/E
I dont know if someone has already posted something about this, so here is what I found on another website. I was reading that over time our throttle cables attached to our gas pedals lose tension and tend to slack.
Sure enough I checked today, I put a rock and press the gas pedal all the way down. Then I looked at the throttle body and sure enough, what was suppose to be WOT was open only a quarter of the way open when the pedal was all the way down.
there was about two inches of slack in the throttle cable I used about 5 or 6 cable ties to tension the cable on the pedal. Now when the pedal is pressed all the way down the throttle is fully open. I got a way better response and smoother down shift for some reason.
I was just posting this so you guys could take a look.
Old Dec 31, 2010 | 01:40 AM
DukesOfHazzard's Avatar
DukesOfHazzard
Will have to keep this in mind and check in the morning, i did this on my stupidroo but i just replaced the cable.
Old Dec 31, 2010 | 01:51 AM
offroadjosh's Avatar
offroadjosh
Did this on my exploder, huge difference! I had totally forgot.. Will have to check the ram tmrw!
Old Dec 31, 2010 | 01:52 AM
Nando Vazquez
The cable ties hold up, but I want to go ahead and replace it. Do you guys know where I could get a good one for a cheap price?
Old Dec 31, 2010 | 01:53 AM
Nando Vazquez
Sorry for the double post, my comp was messing up.
Old Dec 31, 2010 | 01:54 AM
dodgeram07's Avatar
dodgeram07
i kinda did the same thing, just at the over end(at the gas padle)
Old Dec 31, 2010 | 09:20 AM
catota's Avatar
catota
could you post a pic of where to take up the slack please
Old Dec 31, 2010 | 02:39 PM
Nando Vazquez
the easiest would be to take up the slack right at the gas pedal. Get near the pedal and look up under the dash. Pull the pedal forward or towards the seat and there should be some slack there. When you tighten that up it will help open the throttle all the way without bottoming the pedal out sooner. I will post a pic when I get back on campus.
Old Dec 31, 2010 | 02:54 PM
Nando Vazquez
Ill take a look around at the nearby dealerships, maybe online.
Old Dec 31, 2010 | 02:56 PM
UnregisteredUser's Avatar
UnregisteredUser
Never mind.
Last edited by UnregisteredUser; Dec 31, 2010 at 02:57 PM. Reason: Not quite awake today...
