ABS and Brake lights on
Old Jun 15, 2005 | 01:26 AM
2500tn's Avatar
2500tn
Default ABS and Brake lights on
whenever i turn my turck on the ABS and BRAKE lights come on and stay on while the truck is running. wondering if anyone has ever had this problem, the brakes arent acting funny. i also have a superchips programmer and i checked the codes and nothing is coming up with it. help!
Old Jun 15, 2005 | 05:00 PM
Ram4Aaron's Avatar
Ram4Aaron
Default RE: ABS and Brake lights on
Have ya checked to make sure you have enough brake fluid?
Fairly simply, but it'll cause the lights to come on.
Old Jun 15, 2005 | 06:38 PM
steve05ram360's Avatar
steve05ram360
speed sensor on the top of the rear diff is going bad. next your speedo will start acting funny
Old Jun 19, 2005 | 08:16 PM
azffighter's Avatar
azffighter
Go to rockauto.com and you can get that abs speed sensor for 30 bucks. It takes about 5 minutes to replace and no more abs light. As far as the brake light I'd take to Checker auto parts and have them hook it up to their computer and that will solve that.
Old Jun 21, 2005 | 03:05 AM
Wtfd32's Avatar
Wtfd32
I had this on mine i have a 99 its is your rear speed sensor. once that is replaced the lights will be off and if your speedometer is actin wierd it will be fixed. my speedometer didnt move till i reached about 27 mph
Old Jun 29, 2005 | 05:44 PM
neon806's Avatar
neon806
Hey,
I am having the same problem. I have a 98 1500 4x4 5.9L.
Brake & ABS light came on and at the same time the speedometer won't work until @25 mph. Where is the speed sensor located? How hard a fix is it? Autozone does not list that part in their inventory. Does it have another name?
Thanks for the info.
James
Old Jun 29, 2005 | 06:33 PM
Wtfd32's Avatar
Wtfd32
the speed sensor is like 28 bucks at auto zone. i bought it there i dunt know where its located my mechanic did it in like 15 min..
