Code P0505 Idle Air Control system
Old Jan 11, 2011 | 09:56 AM
Still getting the code?
Need to have a look at the wiring for the IAC. sounds like you have an issue there.
Old Jan 11, 2011 | 10:54 AM
dwood1971's Avatar
dwood1971
Still getting code....all wiring has been checked but nothing found.
Old Jan 11, 2011 | 11:07 AM
Grab a friend. Take the filter housing off of the throttle body. Disconnect battery negative lead, and tun on headlights for 30 seconds. Turn off headlights. Reconnect battery. Now, while you are sitting where you can see the IAC pintle, have friend turn ignition on. Does the pintle close all the way, and then back off a bit?
Old Jan 11, 2011 | 01:29 PM
dwood1971's Avatar
dwood1971
do I need to pull the IAC out of throttle body and leave wire connected then turn on key?
Old Jan 11, 2011 | 05:27 PM
No. Don't do that. It will try and run the pintle all the way out..... It needs to be in the TB so there is a 'stop'. The PCM will figger that one out, you just need to be able to see what it is doing.
Old Jan 11, 2011 | 05:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
This may sound crazy, but whenever I change the IAC, I turn the key to the ON then OFF positions 10 times.(without starting the motor). Then I start it and the truck idles perfect.
Old Jan 11, 2011 | 10:38 PM
busaguy05's Avatar
busaguy05
I've been fighting this problem for about 4 years now, and still haven't figured it out. I have even replace the ecm as well all the parts you have, many times. Its got to be something in the wiring harness, I've been slowly working on taking the whole harness out and visually check every inch of every wire that comes or goes from the ecm.
Old Jan 12, 2011 | 07:38 AM
dwood1971's Avatar
dwood1971
How do I see do I see the pintle inside the TB?
Old Jan 12, 2011 | 09:56 AM
You will see the point stick thru the little hole. Take a look down there, and see what it all looks like before you do anything else. Make sure you know what you are looking for, and where.
Old Jan 12, 2011 | 11:52 AM
lord0fsal3m's Avatar
lord0fsal3m
lol, i got the code because i forgot to plug the cable into the very back of the TB, the cable fell behind the motor and didnt even see it. could possibly be the same issue?
