Dodge Ram Throwing 02 sensor codes.
Old Dec 31, 2010 | 08:07 PM
MDrumm03's Avatar
MDrumm03
Well I disconnected the cable and turned on the headlights for 30 seconds.. I let the truck idle for about 5 minutes and no check engine light, but as soon as I took it down the road the light came on and it began to sputter a little bit again..
Old Dec 31, 2010 | 08:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the codes again, and make sure the body lift didn't pull the ground wires off the firewall or backside of head on passenger side.
Old Jan 1, 2011 | 09:35 AM
MDrumm03's Avatar
MDrumm03
Okay I'll try that as well, I checked the ground or I should say grounds off the firewall that connect to the head and they were very tight but seemed to still be connected.
Old Jan 1, 2011 | 09:48 AM
jasonw's Avatar
jasonw
Site Moderator
Check your codes again. Did both codes show up again, or just one?
My guess is still clogged cat. Any exhaust shop can pressure/temp check it.
Old Jan 1, 2011 | 02:14 PM
newman1367's Avatar
newman1367
I would check all the ground connections. Even though everything looks connected, corrosion can keep sensors and such getting a good ground. I was getting a p0138 code and it was from a bad ground.
Old Jan 1, 2011 | 02:21 PM
MDrumm03's Avatar
MDrumm03
Ok, I will check all grounds again.. But I just put the scanner back on it and I am no longer getting code PO138.. (The down-stream 02 sensor).. im just getting PO132.. (Up-Stream 02 sensor being shorted out)...
Old Jan 1, 2011 | 02:25 PM
zman17's Avatar
zman17
Make sure the o2 sensor is plugged in all the way to the harness.
Old Jan 1, 2011 | 03:20 PM
MDrumm03's Avatar
MDrumm03
Ok so I disconnected the negative on the battery and cleaned up the terminals and tightened some grounds.. I found a couple wires that were zip tied to the tranny that looked like they may had been smashed after the truck was lifted so i cut those loose.. Also made sure both 02 sensors were plugged in fully and properly.. I erased the codes with my scanner and the light hasn't came back on yet and appears to be running smoother so far.. It sputtered a little when I first started down the road but hasn't since.. We'll see what happens..
