runnin lean????
Old Jan 4, 2011 | 09:56 AM
Originally Posted by 2000RamHead
ok so I havent replaced the pre-cat o2 sensor yet will do it this weekend but this is why I am replying, the last two mournings it has been about 20-30 degrees out and hasnt acted up at all. so im puzzled, should I still replace the sensor?
How many miles on it?
Old Jan 4, 2011 | 10:06 AM
2000RamHead's Avatar
2000RamHead
104,000 give or take a few hundred
Old Jan 4, 2011 | 11:07 AM
If it hasn't been replaced, it is probably time for a new one then.
Old Jan 4, 2011 | 03:07 PM
UnregisteredUser's Avatar
UnregisteredUser
Replace it.
Old Jan 4, 2011 | 03:21 PM
aim4squirrels's Avatar
aim4squirrels
Id swap the new O2 sensor you bought to the front and the other to the back if the cords will reach. There is no difference in the front or back sensor save possibly the cord length, and the rear only trips a CEL if the cat is malfunctioning. I also remember reading somewhere that when the PCM sees a colder temp reading on the coolant temp sensor, it pulls a pinch of fuel at idle to make the engine heat up faster until the truck reaches closex loop operation. At any amount of throttle tip in over idle, the PCM uses standard values to calc fuel trims.
