higher is better
Old Jun 15, 2005 | 12:50 PM
krikitz's Avatar
krikitz
Default higher is better
ive been readin some old posts about lifts and heres what im thinkin of doin
alot of people have suggested pickin up a set of 3/4 ton springs from the junkyard<probably diesel b/c itll lift it about 3 inches instead of the 2 inches that the gas springs would give> and gettin a set of AAIs for the back
im not too concerned with keepin the smooth ride i have now with the stock suspension, i mean it is a truck, and i am strapped for cash so the big bucks id save goin this route is very appealing
any input? is this a good idea or am i totally screwing my truck over?
Old Jun 15, 2005 | 01:17 PM
steve05ram360's Avatar
steve05ram360
Default RE: higher is better
I have the 3/4 ton coils up front and it gave me about 2 1/2" of lift, then did the 2" blocks in the back so now the front is roughly 1~1 1/2" lower in the front compared to the rear and overall lifted 2+ inches...
my ride is rougher for sure, it handles better however than it did when it was stock.
edit: Oh yeah, another thing, I have RS9000's up front and the stock shocks in the rear, when I have the cover on the bed the ride improves quite a bit. I think the rear shocks are bottoming out which would contribute to the rough ride. Whenever there is some weight in the back, the ride improves significantly...
Old Jun 15, 2005 | 03:07 PM
Silver_Dodge's Avatar
Silver_Dodge
ORIGINAL: steve00ram360
......Whenever there is some weight in the back, the ride improves significantly...
I can concur with that. Last night, I put about 700lbs of sand bags in the back to help flex down my new add-a-leaf. The drive in this morning was much smoother. I also still have the stock shocks in the rear. I am hoping when I put my new ones in the back, that will help too.
Steve, Just curious what setting you run on your Rancho 9000's. When I installed my front ones, I set them both to 4. So far, that feels pretty good for the highway and dips/speedbumps. Going up in the mountains soon, so will see how they feel off road.
Old Jun 15, 2005 | 03:29 PM
krikitz's Avatar
krikitz
haha thats funny both your guys' posts were the ones i was readin about earlier before i posted mine
now i can order those diesel springs online instead of goin to a junkyard
would that be better or should it not matter too much if i did go to a junk yard?
Old Jun 15, 2005 | 03:31 PM
steve05ram360
I used to have them at 4 also but for the little woman, I set it to 1 (softest setting) so she keeps her innards where they belong [sm=bounceybounce.gif]
Old Jun 15, 2005 | 03:34 PM
steve05ram360
ORIGINAL: krikitz
I paid 25 bux for mine used, junkyard! take some brake cleaner to them to make them look close to new again...
Old Jun 15, 2005 | 03:41 PM
krikitz's Avatar
krikitz
good deal
its just a strict spring swap too right? take off and bolt on?
also what about the back? ill do the AALs AND springs? or just AAIs?
i apreciate all the help this is my first project truck so im kinda green...
Old Jun 15, 2005 | 03:47 PM
steve05ram360
the fronts are easy, un-bolt the sway bar, jack it up and the spring will just about fall out, you might need to compress it a little (by hand, it's that loose) to get it out but its easy! but that is for a 4x4, not sure how your 2wd would go...
the backs, I didnt do mine, I had the shop that installed my side steps do it for $25 bux... (I didnt have enought time back then)...
Welcome to DF by the way... you must post a pick of your truck...! we wanna see.
Old Jun 15, 2005 | 03:55 PM
krikitz's Avatar
krikitz
haha if you wanna see what my truk looks like look up an old 94 stock 1500 with beat up weener wheels on it
oh...and its red
but if ur imaginations not too hot ill see what i can swing
thanks for the help i know ill be hittin you up sooner or later when im puttin it all together
Old Jun 15, 2005 | 04:19 PM
Silver_Dodge
Was there really a noticable difference between a 4 and a 1?
