Old Aug 13, 2015, 05:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Removing Upper Dash?
Old Jan 3, 2011 | 10:21 PM
dodgeramit_10's Avatar
dodgeramit_10
I thought about painting my dash but after seeing that picture I think I'm ganna pass. lol
Old Jan 4, 2011 | 07:55 AM
mjonesjr's Avatar
mjonesjr
Taking the top dash out without breaking it requires you to remove the entire dash so you can unscrew the air ducting from the lower dash.
It is a pain in the ***.
Old Jan 4, 2011 | 04:49 PM
newman1367's Avatar
newman1367
there are screws under the dash that i broke off when i tried that VERY SAME THING. my dash is now in pieces. anyone here know where i can get one online
LMC has them. And if you take the A-pillar trim piece off, you should have enough room to run your cable inside of it. I just put 3 gauges on the A-pillar and had enough room for constant power, switch power, ground, and a 1/4" tubing for the vacuum gauge. I started to take the dash out thinking it would be easier to run the wire, but I didn't want to have my dash in pieces and got it done leaving it in.
Old Jan 5, 2011 | 10:00 AM
tango-52's Avatar
tango-52
New dash place:
http://www.plasticpartsinc.com/dodge.html
DodgeMama got one from these guys and pointed me in their direction.
Old Jan 5, 2011 | 10:23 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by tango-52
New dash place:
Geno's Garage carries them as well: http://www.genosgarage.com/prodinfo.asp?number=DRD4-7
