Need some help....
Old Jan 4, 2011 | 04:09 PM
champion88's Avatar
champion88
Check the inline check valve on the passenger side of the intake, that was causing mine to do that on acceleration. You should be able to remove it and blow through it from one side and not be able to from the other end.
Old Jan 5, 2011 | 01:31 AM
98ram4x4slt's Avatar
98ram4x4slt
alright thanks for the help. fixed o2 connector and havent had a problem (knock on wood) but the defrost is permantly on unless i have the whole system off. im goignt to try it tom
Old Jan 5, 2011 | 03:41 PM
BamaRam97's Avatar
BamaRam97
so let me be clear on this. The reason my AC goes from blowing out the front facing vents to the defroster/windsheild vents upon acceleration is because of a vaccum leak at the check valve? I've always wondered why in the heck that happened. I'm going to fix it today.
Thanks!
Old Jan 6, 2011 | 01:57 AM
98ram4x4slt
changed the check valve and defrost goes on and off but i still got the wild vents. and it looks like my new o2 sesor is crap....
Old Jan 6, 2011 | 02:28 AM
merc225hp's Avatar
merc225hp
Did you change both check valves? one at the pass side of the intake and another one up by the pass side firewall, follow the vac lines up and you should see the other one.
Old Jan 6, 2011 | 11:56 AM
BamaRam97's Avatar
BamaRam97
Anyone with Pics of these check valves?
Old Jan 6, 2011 | 12:34 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Read this thread, https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Old Jan 6, 2011 | 02:21 PM
BamaRam97's Avatar
BamaRam97
Originally Posted by zman17
Thanks bud! That helps me out a ton.
Old Jan 6, 2011 | 03:07 PM
BamaRam97's Avatar
BamaRam97
sorry for the double post
