Need some minor help.
Old Jan 4, 2011 | 02:10 AM
Grayfox0092's Avatar
Grayfox0092
Default Need some minor help.
Just a couple questions about bed caps.
My quad cab has the sliding window and I have a Leer Car with the window as well, so it works out. At one point on eBay I saw a sort of gasket you put that goes around the space you'd have if you slid the windows apart, so you'd have a sort of passage inbetween the cab and the bed that wasn't wet.
I have no idea what such a thing is called and Google has really yielded nothing since I don't know what words to search.
Also, what are good ways to make a cap waterproof? My girlfriend and I ended up getting really soaked after sleeping in the bed on a camping trip. Would the main cause be the rubberized stuff between the cap and truck? Just wondering. I remarked we could always toss a tarp over the cap but I'd prefer it just look normal.
Sorry if the questions seem trivial.
Regards,
Pat
Old Jan 4, 2011 | 09:14 AM
redheadhunter21's Avatar
redheadhunter21
When there was a cap on my truck, we put a foam strip between bed and cap and that didnt let water get in, might want to check the windows and brake light to see if they are leaking.
We had a little inflatable bladder basically that sealed from the cab to cap and worked great for trips, kept the cap A/C'd for the dog, we got it from the same place we got the cap, so local place probrably best spot
Old Jan 4, 2011 | 09:25 AM
redheadhunter21
Ok this is similar to what I had only difference is this one does just the slider window the one I had did the whole window
http://www.pickupspecialties.com/Camper_shell_parts.htm
Old Jan 6, 2011 | 04:40 PM
OLE BLUE97's Avatar
OLE BLUE97
on my old ford i had a shell and had the rubber around the backglass. i took the shell off to sell it and where the rubber was it had started to rust. just food for though
