right rear seal leak!?!?!?
Old Jan 5, 2011 | 11:33 AM
bummel23's Avatar
bummel23
Default right rear seal leak!?!?!?
I think i am leaking gear oil from the right rear seal. I am wondering how to change that seal and how long it would take!?
Old Jan 5, 2011 | 11:39 AM
Take the tire off, pull the axle out, take off brake drum, take the hub off, knock out the old seal, press in the new seal (hammer, and a block of wood works fine). Put hub back on, put axle back in, put drum back on, put tire back on. Go in and take a shower, as you will STINK.
Maybe an hour.
Not sure just how the hub is held on. I assume a rather large bolt, holding bearings in place.... can probably rent the right socket from the local parts store.
Old Jan 5, 2011 | 11:43 AM
94Beater's Avatar
94Beater
Here are the steps
- Lift and secure vehicle
- Remove right rear wheel
- Remove right rear brake drum
- Open and drain rear differential
- Take out the cross pin from the carrier
- Remove C-clip on the right hand side
- Pull out right hand shaft out
- Remove bad seal
- Install new seal
- Put everything back together in the reverse order
Make sure to clean the cover and where it seals against the diff.
Refill with fluid
U R ready to go
Labor 1+ hour - make sure to give your sealant some time to dry before filling gear oil.
Hope this helps
