rebuild my 5.9
The 408 needs rather extensive machine work to clear the larger crank, and make sure the rods don't hit the oil pan rails. Not to mention the crank isn't precisely stock... so, they are just a bit expensive.
Try just pricing the crank/rods/pistons for a 408 conversion. The price is scary............
Clearancing the block so the crank throws don't whack it, and blow hole in it. I don't think you can just toss a four inch stroke crank into the block, and simply expect it to work.
Or can you?
Or can you?
grinding the block for rod clearance is a MUST. not to mention any piston modification to set quench. Those are just to name some mods for a stroker particularly, not to mention all of the normal things you would do to a used block.
you should see how close the pistons are to hitting the counterweights...ITS SCARY!
Well the update on my 5.9 rebuild. my dad has bought a used engine from an auto salvage yard out of a 99 durango they told him it would drop right in and run. Looked in the tb and plenum is covered in oil. oh it has 89, 000 miles
