Front axle needle bearing ???
Old Mar 2, 2011 | 11:41 AM
On one of the webs of the central pumpkin, (bracing for where the axle tube goes in....) on the front, should be stamped 44 or 60...... Not stamped real deep though, so, may or may not be legible.
Another possible way to tell is the diameter of the diff cover. If it is around 12", D60, 11 or so, D44.
Five or eight lug axle??
Old Mar 2, 2011 | 07:45 PM
Buellstunter's Avatar
Buellstunter
I just replaced that sat morning in my 96 ram 1500 with a dana 44. I ran into the same trouble, couldn't find the replcement bearing anywhere. even the dealer was stumped. The parts girl at the dealer called a few other dealers and nothin. She talked to a tech in the shop and he told me the needle bearing was replaced with a plastic type bushing. The part number of the bushing I got is 4137740AB. it was $21.15. Seems pretty ****ty to replace a needle bearing with a plastic bushing.
Old Mar 2, 2011 | 09:22 PM
dhvaughan's Avatar
dhvaughan
on my 01 dana 44, i bought the small bushing and needle bearing below. i replaced my large bushing with the needle bearing. those part numbers are dana numbers rather than mopar.
#65 small bushing - 43337
#47 large bushing - 50429
#47 large bearing - 566008
43337 - alljeep.com $5.00
http://www.alljeep.com/oscommerce/pr...ucts_id=167486
566008 - alljeep.com $3.05
http://www.alljeep.com/oscommerce/pr...ucts_id=167605
Old Feb 29, 2016 | 11:03 PM
hotnwildmale44's Avatar
hotnwildmale44
Originally Posted by jeff2323
i was replacing my axle seals and found that this bearing was shot not a big deal but i cannot find this part anywhere?!?! no one seems to know what im talking about i even called the local dodge dealership and they were baffled??
a link would be very helpful
thanks
it is a axe l pilot bearing
Old Mar 1, 2016 | 09:20 AM
5 year old thread.......
Old Mar 1, 2016 | 02:00 PM
94Beater's Avatar
94Beater
Do you have old bearing out?
On the side of it there will be a part number.
Its on the cage holding all the rollers/needles - usually very small font.
Use this part number to get replacement.
For Dana 44 - USA Standard Gear p/n: USA18052 - 1.625" ID, 0.5" Wide
Old Mar 1, 2016 | 04:25 PM
Given the age of this thread, I should hope he has this fixed years ago......
