Cam question
Old Jan 11, 2011 | 09:30 AM
  #21
aim4squirrels's Avatar
aim4squirrels
I did use the newer retainers, as I had already paid for them and they appeared more heavy duty. Perhaps I just got lucky.
Old Jan 11, 2011 | 05:36 PM
  #22
Adobedude's Avatar
Adobedude
Did you by the truck used....Sounds like someone already did a spring swap.
You are correct, the stock beehives are narrower at the top, and why the stock retainers won't work with the .525 and .600 Mopar Performance springs.
Old Jan 11, 2011 | 06:59 PM
  #23
aim4squirrels
No, I was the only owner. Only had 6 miles on it when I drove it off the lot.
Old Jan 11, 2011 | 07:11 PM
  #24
Adobedude's Avatar
Adobedude
Beats me....LOL
Old Jan 11, 2011 | 07:53 PM
  #25
Rockyhigh360's Avatar
Rockyhigh360
IB678, my cam is P#- HER9204ALN. My sig is the "design" lift after 1.7 ratio. I have room for more lift, not much. I opted for lower duration to keep good vac and somewhat low end torque. The higher than usual lift will gives me a snappy throttle and a fast ramp speed. I live @ a high altitude, so erratic idle and low vac does not suit my motor.
Aim, I had "beehive" progressive rate single springs STOCK on my 5.9. I will try to get a pic up. I wonder if they changed springs through the years? I don't doubt your measurements, just seems like another cool little difference in these damn dodges!
Old Jan 11, 2011 | 08:51 PM
  #26
aim4squirrels
oh man, I'm a dip****.
I completely forgot that I have those aftermarket EQ heads on there! No wonder it wasn't stock.
Forget everything I said. I guess posting on the crapper while you're half awake isn't a good idea....
Old Jan 12, 2011 | 05:55 PM
  #27
Adobedude's Avatar
Adobedude
