Truck will start but die after letting up on gas
Old Jan 11, 2011 | 07:19 AM
rangerr72's Avatar
rangerr72
Default Truck will start but die after letting up on gas
My 2001 Ram 1500 (4WD) had a dead battery yesterday. I charged the battery and now it will start right away but dies when I let up on the gas. I thought it might be the IAC but I am worried about why the battery was dead to begin with. Any ideas?
Old Jan 11, 2011 | 07:23 AM
bwdakrt's Avatar
bwdakrt
Battery's too weak to keep it running. Replace it and you're golden.
Old Jan 11, 2011 | 07:59 AM
zman17's Avatar
zman17
Retired Moderator - RIP
+1, and after you replace the battery the PCM will need a little time to relearn the IAC settings.
Old Jan 11, 2011 | 08:13 AM
dhvaughan's Avatar
dhvaughan
your battery is probably still low on voltage. check it with a voltage meter and load test.
low voltage screws up the idle signal.
