Dying at stop
Old Jan 13, 2011 | 08:10 PM
got_ink123's Avatar
got_ink123
Default Dying at stop
Alright, I'm over here in Philly, the truck sat for about a week because i was worried of someone stealing my spot so I kept taking my wife's car since no one can park infront of our garage. Anyway... today I ran out and it had the ever so slightest problem starting, just a bit of hesitation but it started and ran. I hopped on the highway it ran fine for 2 miles. At my third light it stalled (it's an auto) then stalled everytime I stopped without holding the gas and the brake at the same time on the way to and home from my destination.
So I ran a volt meter on it, 12.3volts when off, 14.4 when running @ idle... When I went to run the volt meter I couldn't get it to stall but I brought it out to 5grand and when i let off, it went to stall but caught itself... it slightly dipped when this happened and hit 13.7volts... so I don't think it's my battery / charging system.
The IAC and TPS were both recently replaced. The truck also has new plugs and wires. I'm at a loss for why it's acting like this... any ideas?
Old Jan 13, 2011 | 09:23 PM
OLE BLUE97's Avatar
OLE BLUE97
this just happened to me a month or so ago. i cleaned my IAC and everything has been dandy since. make sure you unplug your battery before doing it though.
Old Jan 13, 2011 | 11:05 PM
dhvaughan's Avatar
dhvaughan
i'd reset the pcm by disconnecting negative battery cable and turning on headlights for 30 seconds - see if it fixes itself. if not i'd charge the battery or drive it/idle it for awhile and let the alternator recharge battery.
Old Jan 14, 2011 | 11:53 AM
99ramjrbo's Avatar
99ramjrbo
I had the same problem with my 99 1500. Every time i would stop i had to keep one foot on the brake the other on the gas. I got some carb and choke cleaner, and with the engine running sprayed about 2 squirts in the carb. Knock on wood i have not had a problem since. There was a post on it a little while ago in this forum.
Old Jan 14, 2011 | 12:03 PM
BamaRam97's Avatar
BamaRam97
Not saying this is your problem, but make sure you clean the battery posts really well. I had a workaholic battery and I had to clean the post and cable about once a month to keep it working right. If I didn't I'd have to do exactly what you say to keep the truck running at red lights and stop signs. I have an Optima red top now and have no problems.
Old Jan 14, 2011 | 12:28 PM
Flue's Avatar
Flue
+1 on the terminals. My neg term was slightly corroded and started causing me the same issues. Once I cleaned the posts and freshly charged the problem went a way.
Old Jan 15, 2011 | 12:14 AM
pavement_hater's Avatar
pavement_hater
Is the check engine light on? If the neutral safety is bad and showing ground all the time to the PCM it will stall every time you stop. It usually causes a check engine light. Atleast it does in my truck.
Old Jan 15, 2011 | 12:19 AM
matty675's Avatar
matty675
might wanna replace your carb
clean your TB and reset the PCM
