wont start
Old Jan 13, 2011 | 09:28 PM
bigcountry911's Avatar
bigcountry911
Default wont start
driving down road just shut off wont restart
Old Jan 14, 2011 | 10:47 PM
matty675's Avatar
matty675
will it turn over?
Old Jan 14, 2011 | 10:49 PM
If it will crank, but, not start, swap the asd relay with the wiper relay. See if that improves its attitude.
Old Jan 15, 2011 | 12:35 PM
bigcountry911
Default wont start
i tred that nuthin happen any other things i can try
Old Jan 15, 2011 | 12:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You think you could put all the info about your truck in your sig? You can try getting any codes by reading this https://dodgeforum.com/forum/2nd-gen...code-list.html
Only works on certain years, and we don't have that info!
Old Jan 16, 2011 | 12:12 PM
Skab's Avatar
Skab
The best way to check this from my recent experience is to turn the key to on and listen by the gas cap for whine or electrical noise, that will be the fuel pump turning on or not if you don't here any noise.
After that depends on what year, eng type, and model for next steps.
Old Jan 17, 2011 | 05:58 AM
bigcountry911
Default roll over wont start
hey guys thanks for aal the good ideas i have check my lift pump and wasnt hardly pumping i took a shot in dark replaced lift pump 200 bucks later bam it worked running like cummins should
