4x4 question
Old Jan 26, 2011 | 11:08 AM
Kevin A Crider's Avatar
Kevin A Crider
Just wanted to hop in and say thank you for the detailed posts in this thread. My 4x4 is also not working and this will give me a good place to start.
About 3 weeks ago I noticed the vacuum lines were cut (or appeared cut, both were sliced at the same spot) and after splicing them back together I still can not get 4x4 to engage. I do not get a light on the dash either.
Old Jan 26, 2011 | 11:11 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You probably have a vacuum leak further up the system. Does your heat work normal and cruise control if you have it?
Old Jan 26, 2011 | 11:15 AM
Kevin A Crider
Yes, my heat works great. I've not tried to use my cruise control since the 4x4 stopped working but it worked before hand. Also, my 4x4 worked great right up until the lines were cut.
Old Jan 26, 2011 | 11:25 AM
zman17's Avatar
zman17
Check out this link, http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Jan 26, 2011 | 11:28 AM
Kevin A Crider
Thank you! I actually had that exact page already open in another browser tab but didn't get a chance to give it my undivided attention. Work gets in the way!
