Transmission Wiring Harness
Old Jan 15, 2011 | 12:49 AM
ramtow's Avatar
ramtow
Default Transmission Wiring Harness
New to the forum. I have a 97 Ram 1500 with 5.9 and 4 speed auto. It recently stopped shifting out of 1st. Replaced the speed sensor and did not resolve the problem. I have purchase the Pressure Sensor, solinoid and wiring harness. I have the sensor and solinoid out but do not know how to pull the wiring harness. I have searched the forum but have not found any mention of exactly how this is done. Photos of what to pull would be a great help. I am mechanically inclined but I have not worked on Automatic Transmissions before.
Thank You.
Old Jan 15, 2011 | 01:06 AM
matty675's Avatar
matty675
only replace the solenoid and sensor
Old Jan 16, 2011 | 02:39 PM
ramtow's Avatar
ramtow
Following your advice I just replaced the sensor and the solinoid. Transmission is now back to normal. After pulling the old parts it looks like the solinoid screens were clogged and not allowing fluid flow. It is possible I could have cleaned the screens and reinstalled the old parts. There were alot of metal shavings in the fluid and around the magnet and there were a couple of small metal pieces. I wish I had put in a drain plug because I can see changing the fluid again in the near future.
