99 Ram 1500 5.2 Engine misfire low RPM's
Old Jan 18, 2011 | 12:10 AM
vast8fm's Avatar
vast8fm
Default 99 Ram 1500 5.2 Engine misfire low RPM's
My 99 Dodge Ram 1500 5.2 is misfiring running at low RPM's and when going up hills. I have replaced the plugs, cap, rotor, and wires. The motor seems to run fine under idle. Any idea's? I have been told maybe a crank sensor.
Old Jan 18, 2011 | 12:20 AM
Have you looked at your plenum yet? Checked fuel pressure?
Old Jan 18, 2011 | 12:39 AM
matty675's Avatar
matty675
what is YOUR definition of a misfire?
Old Jan 18, 2011 | 10:45 AM
mfabris04's Avatar
mfabris04
I have the same problem around 40-50 and my 5 and 8 plug look like they are the ones misfiring. I thought it was the routing of the wires but it did not solve the problem. Will a blown plenum do this???
My 5 and 8 plugs do have oil on them or burnt oil. Maybe I will do the vaccuum test this week to see. If some one comes up with a better idea please let me know.
Old Jan 18, 2011 | 10:47 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Plenum gasket, precat o2 and cat is shot/clogged or almost there.
Old Jan 18, 2011 | 10:51 AM
mfabris04's Avatar
mfabris04
I will take some runs with the pre cat O2 out and see if it helps. Thanks for the advice.
