idle question/problem
Old Jan 18, 2011 | 11:04 PM
98ram4x4slt's Avatar
98ram4x4slt
i dont blow smoke unless i floor it but the exaust is always carboned up really bad
Old Jan 18, 2011 | 11:05 PM
Get a PCV valve from the dealer. I bought the 'good one' from advance, and STILL went thru oil like there was no tomorrow. Replace the PCV with one from the dealer, end of problem.
Old Jan 18, 2011 | 11:09 PM
98ram4x4slt
you know how much the dealer one is going to set me back
Old Jan 18, 2011 | 11:19 PM
PurplDodge's Avatar
PurplDodge
< $10
I'm not convinced that your plenum is not blown. Here is the end all for your plenum, do the test:
http://dodgeram.info/tsb/2000/09-05-00.htm
Old Jan 18, 2011 | 11:28 PM
UnregisteredUser's Avatar
UnregisteredUser
Right around eight bucks.
Old Jan 18, 2011 | 11:40 PM
98ram4x4slt
i just replaced the plenum cuz i figured that was it. plenum was blown. but ive taken care of it
Old Jan 19, 2011 | 11:24 AM
98ram4x4slt
i still dont understand the idle. could i have a bad fuel injector and be washing the walls? is there a way to test them
Old Jan 19, 2011 | 11:35 AM
If you are still sucking oil, it will still foul plugs, and give you a miss. If you are getting misfire codes, is it for specific cylinders? Or, just random?
Old Jan 19, 2011 | 12:35 PM
98ram4x4slt
sometimes i feel like i have a mis. i would get mis fire codes with #2 cylinder when i had the old o2 sensor. but i still feel a miss but no codes
Old Jan 19, 2011 | 01:03 PM
You will REALLY feel if you have a miss at about 45 mph, when the truck shifts into O/D, and TCC engages. It will be a pronounced vibration.
If it is consistently cylinder 2 that is misfiring, and the plug and wire look good, swap the #2, and #4 injectors, and see if the misfire moves with the injector.
Also wouldn't hurt to run a compressions check.
