Need help please!!
Old Jan 18, 2011 | 11:03 PM
97Rampowerhouse's Avatar
97Rampowerhouse
Default Need help please!!
Hey guys im looking to get a 2 inch leveling kit for my truck and new tires and wheels. My question is what is the biggest tire I can put under it being its stock plus the 2inch level front kit. It currently has 265s on it.
Old Jan 19, 2011 | 12:02 AM
97Rampowerhouse
figured i would get a quick response there fellas oh well had to resort to google!
Old Jan 19, 2011 | 12:03 AM
285's will fit fine without much rubbing. and even then, just on the control arms at full lock.
Old Jan 19, 2011 | 12:05 AM
97Rampowerhouse
thank you!!!
Old Jan 19, 2011 | 02:07 PM
stnlycup's Avatar
stnlycup
Have the 2in leveling kit on mine...285 BFG's dont rub at all anytime on mine
Old Jan 19, 2011 | 04:23 PM
Big Guz's Avatar
Big Guz
265-285- you know you guys are talking about the width, right. 265=10.4 inches wide, 285=11.3 inches wide. Diameter, and offset matter too. I run 33x12.5x15 which would be about 315-75-15. I have no lift yet and they only rub my step bars when I make a hard turn. With the right offset you could run a bigger tire.
Old Jan 19, 2011 | 04:43 PM
Silver_Dodge's Avatar
Silver_Dodge
You are correct, but when people around here say 285, they are just refering to 285/75/16 or 285/70/17. Both of which basically the same as a 33 except narrower. It's just easier to say 285. We all know what they mean since 265's and 285's are about the most common tire that came on 2nd gen Rams.
Old Jan 19, 2011 | 05:25 PM
redheadhunter21's Avatar
redheadhunter21
If you keep it on the road and dont mind a little rubbing you could get away with 315/75, also a 305/70 should fit with at most slight rub on control arm, this is assuming you keep close to stock rims, get a little less back space and dont go to wide and 315/75's can fit without rub
If you offroad stick to 285/75, or 305/70
